Saw this and it looks like the dip stick is in the correct place for an evo sump?
http://www.speedhunters.com/2011/07/car ... style_e30/ for the rest of the photos!
jmc330i wrote:I've also heard of the possibility of using the E36 subframe, but its not straight forward from memory. I can't remember the problems.
It is certainly easier to use the M50 sump (and change the oil pump on the 3.2 lump).
The E36 subframe has the engine mount tabs on the opposite site compared to an E30 subframe. Bolts up, but engine position is not suitable. As mentioned before, you need to cut a large hole in your fire wall to make room for th engine.DanThe wrote:The E36 crossmember does bolt up but the engine is so far back the bulkhead/trans tunnel needs major surgery
