S50 Bearing Sizes
dicko
Post Tue Jun 26, 2012 9:17 pm
I am rebuilding my friends S50b30 to go into his e30 325i sport , and I am looking for a chart with the bearing sizes that correspond with the different colours , The orginal bearings were only a little worn and the crank was just repolished so still just under 60mm
the problem is the colour marks on the block are very faint and unreadable and I cant find any on the crank ? when I took it apart , I found a bit of green paint on the first main bearing shell but none on any of the rest . also in Tis it says to ignore the paint class on the block and only fit yellows in the block, It seems a bit strange fit odd shells . So hope there is a Master tech on here who can help!
dicko
Post Tue Jun 26, 2012 10:09 pm
I found it eventually I must install my Tis on my computer http://tis.spaghetticoder.org/ Is a bit of a pain . here are the links in case any one else has the same problem http://tis.spaghetticoder.org/s/view.pl?3/04/27
http://tis.spaghetticoder.org/s/view.pl?1/01/04/73
