ARB near exhaust manifold/wishbones
crossie
does you Arb tap/hit your exhaust manifold?
or is it fine one the car is on the ground - only problem while on axle stands?
I only got this when he car was in the air when I had my S50 manifold on the M52 in the touring.
But I think the pipes had been modified from standard too and they still touched with the suspension free to hand down.
backspring
mine touched whilst jacked up but when on the ground left me with a 1cm gap, didnt feel comfortable with it so i ended up using spacers on the arb mounts, now i have 3cm.
but some people dont have problems i did.
jmc330i
What exhaust manifold are you using? Never had a problem on mine - in the air or on the ground.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
ajay
Mine looked like it would never clear the btb exhaust when it was up on a 4 arm ramp but cleared with no issues when on the ground!
crossie
S50 standard manifold
do you have a photo of your spacers?
jmc330i
Modified to fit the E30 I take it?crossie wrote:S50 standard manifold
Mine was a btb one, which is basically a modified S50 manifold. Sounds like you might need to space the arb down a little to get the clearance if your manifolds weren't modified enough to clear them.
James
'91 325i Sport
'91 325i Sport
DMS
Just make a new ARB
crossie
LOL - E30 modified to take the S50 manifold!jmc330i wrote:Modified to fit the E30 I take it?crossie wrote:S50 standard manifold
jmc330i
Interesting.... get some pics up. That is a different approach to the conversioncrossie wrote:LOL - E30 modified to take the S50 manifold!jmc330i wrote:Modified to fit the E30 I take it?crossie wrote:S50 standard manifold
It would also explain the manifold hitting the ARB I guess. You may struggle for advice as most conversions on here use modded manifolds, rather than completely standard ones with the car modded around them.
At a guess (without seeing pics), you'll probably have to space the ARB down.
James
'91 325i Sport
'91 325i Sport
crossie
Sorry no photos yet just seen this.
My car is lhd so helps with getting the manifold to fit.
Will post photos tomorrow
jmc330i
Ah, yup LHD definitely helps lol
James
'91 325i Sport
'91 325i Sport
DMS
That's exactly my approach:jmc330i wrote:It would also explain the manifold hitting the ARB I guess. You may struggle for advice as most conversions on here use modded manifolds, rather than completely standard ones with the car modded around them.
-modify firewall
-modify subframe
-change ARB
-different lollypop
My car is also a LHD
PazzaAE86
I spaced the ARB down, modified the firewall and ran treehouse racing lollypops to clear the manifold, but the manifold sits too low so the bottom flanges will need cutting off and welding higher up, unless your car is mega high.
crossie
PazzaAE86
Which mounts are you using?
PazzaAE86
Sorry for the late reply, i used the traditional M5 mounts, modified to be stiffer.
crossie
no worries mine is almost done and finished now
am sure it will be too low but at the minute stardard is all I can afford!
