How do you remove the fan off the S50 engine?
crossie
Mon Apr 09, 2012 7:36 pm
Mon Apr 09, 2012 8:17 pm
With a slim 32mm spanner. L/H thread.
As you have no belts you will prob need a tool to hold the water pump which is a long flat plate with two holes that the the water pump bolts fit into.
crossie
Mon Apr 09, 2012 8:38 pm
thanks will look at that tomorrow
PazzaAE86
Mon Apr 09, 2012 9:09 pm
You can tap downwards with the spanner slightly to the right (as you look above the fan) on the spanner with a hammer and that is sometimes enough to un-do the nut... Sometimes not. lol.
crossie
Thu Apr 12, 2012 8:05 pm
what spannor size is it?
glenn
Engine Transplant Services
Thu Apr 12, 2012 9:38 pm
crossie wrote:what spannor size is it?
bss325i wrote:With a slim 32mm spanner. L/H thread.
:wink:
crossie
Sun Apr 15, 2012 5:00 pm
:wink:
doh
cheers
