Fuel Pumps S50 b32
Aziz
Fri Jul 29, 2011 7:42 pm
wanting to know which fuel pump people are using on the above conversion.
Im wanting a quite-ish pump, so what do you guys recommed from personal experiences.....
all feedback welcome
Imran
Gunni
Fri Jul 29, 2011 9:08 pm
stock
Gunni
@ 2012 VEMS group buy !!
penton08
Fri Jul 29, 2011 9:16 pm
Gunni wrote:stock
+1, e36 evo pump in the e30 hanger.
Aziz
Fri Jul 29, 2011 9:22 pm
penton08 wrote:
Gunni wrote:stock
the car in question is a tech 1 with internal and external pump??
UweM3
Sat Aug 13, 2011 11:47 am
I was planning to use a S50 EVO pump in my M3 and use the intank pump as lifter pump to fill a swirl pot in which I mounted the pump. All fitted in the boot. Few pictures.
Pump assembly from E36 M3
form follows function swirlpot made from Stainless Steel
with pump inserted
fitted in the boot with the E36M3 fuel filter
tested to 2bar (29psi) pressure before fitting it. The black plastic is the pump retainer bracket.
Aziz
Tue May 21, 2013 6:27 pm
penton08 wrote:
Gunni wrote:stock
thanks for the advice.
To give an update I've fitted the evo pump in e30 hanger all is working well.
Question is my car is a tech 1, so I've taken out the external pump made electrical wiring safe.
I'm using the original power source which is at the e30 hanger for the lifter pump.
Ive noticed over a few days that the electrical wires are getting hot. Is this usual?.....
OR
Should I extend and use the wiring from the external pump?
I'm worried It may catch fire :eek:
Thanks Imran
ajay
Tue May 21, 2013 7:46 pm
Are the cables at the hanger the same gauge (thickness) as the cables that used to feed the external pump? If they are a smaller gauge then STOP using them and extend the ones for the external pump. If your not sure get someone to check! At least its all fine, at worst your heading for a fire!
Aziz
Tue May 21, 2013 8:06 pm
ajay wrote:Are the cables at the hanger the same gauge (thickness) as the cables that used to feed the external pump? If they are a smaller gauge then STOP using them and extend the ones for the external pump. If your not sure get someone to check! At least its all fine, at worst your heading for a fire!
both cables look like a similar gauge, I know as more fuel is required the pump draws more ampage.
Just checking that E30 wiring is up to the job supplying power for the Evo pump.
Aziz
Thu May 23, 2013 11:23 am
Update
I've extended the wiring from the external pump ti the new intank.
Drove the car for about a hour everything seems ok wiring not excessively hot.
Feel at ease now.......can put rear bench back down.
Thanks everyone
Just a thought the E46 M3 fuel pump is 5bar can this be fitted into E30 hanger??
Imran
ajay
Thu May 23, 2013 12:08 pm
I do have 1 and did think about trying it but ended up using an external pump in the old location, (5 bar no issues and quiet too).
Aziz
Thu May 23, 2013 5:15 pm
ajay wrote:I do have 1 and did think about trying it but ended up using an external pump in the old location, (5 bar no issues and quiet too).
I couldn't live with the external pump the humming/buzzing very annoying no matter how quiet it seems in the car when your out you can hear it.
May pickup a E46 pump see whats involved.
Peace Imran
ajay
Thu May 23, 2013 5:30 pm
Ah i see, no chance of hearing any such thing on my E30 once its running. I would offer you my m3 pump but the tank is at the back of one of my garages ( under piles of stuff) so it a headache to get it for not much ££. GL
jmc330i
Thu May 23, 2013 5:35 pm
What's wrong with the E36 Evo pump?
James
'91 325i Sport
'93 318i touring 16v
Aziz
Thu May 23, 2013 9:17 pm
Nothing just wanted to see how easy it is to put into e30 hanger.
possible upgrade if something goes wrong.
Evo pumps are over 10yrs old now so who knows.
Imran
