Part numbers
pdd144c
Post Thu Jun 23, 2011 7:11 pm
Hi
Just doing a S50 conversion on my track/race car and require a little help with part numbers. I have got nearly everything else I need from realoem but can't find the following:
M50 525 oil pump and pick up (possibly 11411740155 but can't see if the pick up is included?)
E36 M3 LHD waterpipe, which pipe is this and why is it used?!
Cheers in advance,
Paul.
UweM3
Post Fri Jun 24, 2011 8:49 pm
pdd144c wrote:Hi
Cheers in advance,
Paul.
haven't got the P/N at hand for the LHD water pipe, it's used to have the coolant overflow bottle on the battery tray to free some space next to the engine for an airfilter.
Post Fri Jun 24, 2011 10:14 pm
Pick up does not come with the pump
LHD water pipe = 11531318403
pdd144c
Post Tue Jun 28, 2011 6:51 pm
Thanks.
Really Dan? Spoke to a mate who ordered one the other day and it did... Strange! Also I forgot to send the money for the linkage, will get it sorted later this week.
Paul.
Post Tue Jun 28, 2011 7:20 pm
He got lucky then! Look at this link and you will see they are two separate part numbers - http://bmwfans.info/parts/catalog/E34/S ... ith_drive/
pdd144c
Post Tue Jun 28, 2011 8:11 pm
Random! Same pic as I found on realoem, looks like the pickup is part of it to me... I'll order just the pump and see what happens!
