engine swap temp sensor
moggie
hi,can anyone tell me if you have to swap the temp sensor on the s50b32 m3 evo engine when putting it in an e30,if so which one will i need?much appreciated if anyone can help,this is the last thing to sort out before the engine goes in
RoadHazard
The black temp sender will need to be replaced by the brown one from the M20 (1 pin).
moggie
thanks,does it screw staight in like for like?
glenn
- Engine Transplant Services
the 'black' one needs to stay.
its sends information to the ecu.
you can screw the m20 brown sensor into the water manifold next to the black one. theres an 'allen' bolt there that you can remove and replace with the m20 sensor. then take the brown/purple wire from the black plug and put it to the m20 sensor
moggie
thanks for info i nearly just swapped them round
