S50B30 in a E30 Touring, which gearbox
vanos
I got a S50B30 and matching gearbox to go into my E30 Touring, is it best to keep the gearbox or can I fit my 325i gearbox to the S50B30 engine, I have an LSD from a 325i sport mtec 2, it's a 3.64 ratio.
If I use the M3 gearbox will I have to change the LSD to a different ratio'd LSD ? and what would be the best LSD ratio ?
If I kept the 325i box I can keep the LSD and keep it the same.
Gunni
The 3.64 will be kinda short for the 5gear S50 box. But will still be nice to have for acceleration.
I used to use a 3.25 diff with my S50 and I felt it was the ideal diff ratio.
vanos
Thanks Gunni, cant use the 325i gearbox then ?Gunni wrote:The 3.64 will be kinda short for the 5gear S50 box. But will still be nice to have for acceleration.
Gunni
Only with a M20 flywheel and clutch combo I believe as the 240mm pressure plate is to large for the M20 bellhousing.
e21Jason
Also the 325 gearbox will sit at the wrong angle
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
Gunni
That´s not really a problem in the long run, as long as you adjust the gearshifting mechanism.
vanos
So I'd better get looking for a 3.25 lsd from a E30 M3 then, seen one on ebay for £480
, whats a reasonable price for one
Anybody after a 3.64 LSD
Thanks for the help guys
UweM3
M3 track day guys will be after your 3.64 LSD. Maybe a swap??
vanos
Thanks Uwe, is it best to post it in wanted and forsale for a swop ?UweM3 wrote:M3 track day guys will be after your 3.64 LSD. Maybe a swap??
beardymat
- Location: sheffield, city of steel, and rust apparently
Im running the five speed 3.0 box on a 3.2 with the standard 3.25 M3 diff and its pretty good although with my exhaust can get a little tiresome at motorway speeds. Keeping a 300bhp spec clutch in there makes sense to me.
UweM3
do you know top of your head the revs at 70mph or 80mph?beardymat wrote:Im running the five speed 3.0 box on a 3.2 with the standard 3.25 M3 diff and its pretty good although with my exhaust can get a little tiresome at motorway speeds. Keeping a 300bhp spec clutch in there makes sense to me.
beardymat
Not exactly at the moment but im off out in it tomorrow on the motorway so ill take a note. somewhere between 3-4k at 70 is my best guess right now.
UweM3
I only want to compare the revs at 70mph to the S14 I had fitted before to see if I run out of RPM in 5th gear.beardymat wrote:Not exactly at the moment but im off out in it tomorrow on the motorway so ill take a note. somewhere between 3-4k at 70 is my best guess right now.
Between 3 and 4k is a HUGE difference in speed. I would be grateful if you can narrow it down to 100-200 revs.
From memory i was running about 4.4k with the 3.73 diff with correct sized tyres but the S14 revved up to 8k and I don't want to rev that high with the S50B32 if I can avoid this (have a 3.25 diff fitted now BTW)
This is with an M3 diff and 205/50/15 tyres, 1:1 5th gear
With S50 power id want a diff more in the region of 3:1 for a road car
- Homo Hair
4k is 90 with the 1:1 and 3.25.. 22.5mph/1000rpm iirc
UweM3
I was planning to run a 3:25 and maybe larger tyres if the gearing is too short. But mine is not a road car primarily.
Tyres I should use are 225/45/16 but I want to run 225/45/17 and maybe 255/40/17 rear
if I can make room in the wheel arches without too much cutting.
- Homo Hair
Mine was running 215/40/17 btw..
beardymat
Well I took note today and at a speedo indicated 70 it was doing 3100 revs but doing 70 by the sat nav saw it doing more like 3500. That's running 16" Evo wheels with standard size tyres.
RoadHazard
Stock E36 M3 is 3.15, isn't it? That's what I'm using.
glenn
- Engine Transplant Services
i'm not sure on standard 3.0's, but the evo's are 3.23:1RoadHazard wrote:Stock E36 M3 is 3.15, isn't it? That's what I'm using.
Yep, 3.15 on a 3 litre, thats what im using now with my 6 speed box, gives this in 6th -
RoadHazard
That makes sense because of the different gearing between the 5-speed and 6-speed.glenn wrote:i'm not sure on standard 3.0's, but the evo's are 3.23:1RoadHazard wrote:Stock E36 M3 is 3.15, isn't it? That's what I'm using.
RoadHazard
Maybe I should try 2.93 with the 5-speed. That would give a similar result in the last gear, would it not?DanThe wrote:Yep, 3.15 on a 3 litre, thats what im using now with my 6 speed box, gives this in 6th -
No, you would be approx 10mph slower @ 3000rpm, although it would be much better for driving on the road
Mikey_Boy
Sorry to be a bit off thread here, but are there really no issues with canting the E30 325 gearbox over another 15 degrees???
Considering an S50/M52 for mine with an E30 M3 gearbox with a direct drive top (which I already have fitted to the car), but a bit concerned about lubrication in the box??
Apologies again, but any pearls of wisdom are appreciated!
For what its worth - have a look at this:
http://www.catherineandken.co.uk/sti/tyres.html
This works out top speed in every gear and quite useful... For me as my car is used mainly for trackdays, having 4k on board at 80 is a small price to pay for the responsiveness on track, but of course I would do something else if it was a daily driver!
Cheers,
Mike
Cheers,
Mike
Gunni
It´s been done countless times in M50 conversions and I´ve never heard of issues.
Mikey_Boy
Thanks Gunni! Most helpful...!
Cheers,
Mike
Cheers,
Mike
e21Jason
I am running a s50 with a 265 getrag and a 3.9 diff but I tilted the engine and kept the box at the original angle as the s5O goes straight on the m20 mounts
Jason
Jason
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
- Homo Hair
Not sure I would fancy doing that.. I would be constantly shitting it about oil pickup! (Not saying it doesn't work, just I wouldn't do it..)e21Jason wrote:I am running a s50 with a 265 getrag and a 3.9 diff but I tilted the engine and kept the box at the original angle as the s5O goes straight on the m20 mounts
Jason
e21Jason
Twin pick up with modified sump pan with "wings"
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
- Homo Hair
Didn't think it would be a stock setup to be fair..
Mikey_Boy
+1
Definitely required and well executed I am sure!
Another option to consider darn it!
I bet an S50 with 265 box and 3.9 diff goes like stink.......!
The gear ratios would be similar to using an E36 box and 3.25:1 diff
