Clio servo - which master cylinder? S50 engined cars.
jonnie
Post Fri Dec 24, 2010 2:24 pm
Hi guys, just about to start an S50B32 build (will get a journal going very soon) and am about to buy a clio servo.
One question though, I've searched through loads of posts, but cant seem to find a definitive answer.
To those who have used the clio servo on their s50 engined cars and have moved the servo over 55-60mm, what master cylinder do you have?
Many Thanks in advance for the help. :D
Gunni
Post Fri Dec 24, 2010 10:27 pm
I used the stock one.
Gunni
@ 2012 VEMS group buy !!
RoadHazard
Post Mon Jan 03, 2011 5:02 pm
The stock one fits. I used the 25mm one from the E32.
jonnie
Post Mon Jan 03, 2011 5:45 pm
Thanks guys appreciate the replies.
Good to know the standard one fits, but think I might go for the E32 one as I'm going to be using e36 m3 brakes.
RoadHazard
Post Mon Jan 03, 2011 5:49 pm
Sorry I just recalled that if you use a stock master cylinder, you will need a spacer to fill in the rod as the rod on the clio servo is too short. Can't remember the length though. I think it's around 20mm or so.
jonnie
Post Mon Jan 03, 2011 5:52 pm
But not with the e32 one you used?
RoadHazard
Post Mon Jan 03, 2011 5:55 pm
You'll need a spacer for the E32 one too. Same length.
jonnie
Post Mon Jan 03, 2011 5:57 pm
Cool, thanks.
