S50 into e36 318i running problems
Trise30rally
Post Mon Jan 11, 2010 4:29 pm
Basically i have an s50b30 plugged into an e36 318i wiring loom in my e36 rally car.
I know this is not an e30 but you guys are the most experienced at fitting s50's in strange places! :D
I am having a few teething problems with my engine though,
Firstly the idle is not smooth at all, i put it down to coil packs so i swapped a suspected faulty one and i got a slight improvement but still no where near smooth.
Next problem is the engine stalls if you let go of the throttle but it will idle if you gently release the throttle....
And then, it seems to be down on power, bottom end grunt is great but top end seems flat, almost as though the VANOS is not kicking in...
And fuel consumtion is HUUUUUUUGE :D
The only things i can think of that are not standard are,
I have not fitted this extra speed signal wire i have heard rumours about, apparently only M3 wiring looms had this wire so do i need to fit it? What does it do exactly?
Carbon canister sensor, i have a 328i one plugged in but it is not sensing anything, its just cable tied up.... What does this do exactly??
glenn
Engine Transplant Services
Post Mon Jan 11, 2010 6:23 pm
have you got the lambda's plugged in the correct pipes?
J70NEY
Post Tue Jan 12, 2010 12:52 am
take it u have an air flow metre in the car? check if its the correct part number.. ive had similiar probs & after a lot of messing about with coil packs, plugs & wiring i found it had the wrong air flow metre!! worth a try.. let me no how u get on!!
Trise30rally
Post Tue Jan 12, 2010 9:19 am
Hi, How do i know if i have the lmbda's plugged into the correct pipes?
It is deffinately the correct air flow meter because it all came out of this car originally, basically i bought an e36 m3 with a roll cage and no wiring loom so i scrapped a 318i auto and fit the wiring loom from that into the m3.
UweM3
Post Tue Jan 12, 2010 1:05 pm
IRRC Jhonno had some idle problems and misfires on part throttle solved with the speed signal from the diff
Trise30rally
Post Tue Jan 12, 2010 4:01 pm
I have just done a little research on the speed sensor wire and it seems that some need it and some don't.
Does anyone know the symptoms of a motor that needs a speed signal?
