Need some torque settings and a few questions
RoadHazard
Post Wed Dec 02, 2009 3:11 pm
I'm preparing the S50B30 engine for a swap into my E30.
Can any one help me with these torque settings please?
Oil pickup tube bolts
Main bearing cap bolts
Oil filter housing bolts
Also, when remove oil pickup brackets from the main bearing caps do I need new bolts?
Do I need to use E34 sump bolts or E36 ones are fine?
Thank you.
Post Wed Dec 02, 2009 7:02 pm
Mains bolts are not stretch, so no need to replace, I just bend the bracket over though. Both sumps use the same bolts
http://www.e30zone.net/modules.php?name ... c&t=134960
RoadHazard
Post Thu Dec 03, 2009 7:13 am
That's good to hear. Thanks DanThe
One more newbie question.
When it says 20 Nm and 50 degrees, does it mean either is fine or to do it in sequence?
penton08
Post Thu Dec 03, 2009 5:50 pm
tourqe in sequence to 20 Nm, and then in the same sequence tighten a further 50 degrees. you will need a angle gauge to do this properly, or you can make one quite easily.
