What engine mounts should i use
feens
As title ive read that the e28m5 engine mounts are a bit soft for the s50 conversion what other mounts should i use? Poly mounts were mentioned but ive no idea off what car ect
Thanks Brian
Thanks Brian
S50B30 E30
billgatese30
I have AKG mounts on mine and they work great, they are pricey though.
http://www.akgmotorsport.com/e30products.html
Second from the bottom of the page.
feens
Cheers for that dude
S50B30 E30
BMWLOVE100
get the same mounts you used to have
jmc330i
Ive had no problems with mine.feens wrote:As title ive read that the e28m5 engine mounts are a bit soft for the s50 conversion
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
- Homo Hair
I did.. Fine with AKG's..jmc330i wrote:Ive had no problems with mine.feens wrote:As title ive read that the e28m5 engine mounts are a bit soft for the s50 conversion
You will be fine until you start taking hard left handers, track day etc.
- Homo Hair
Or hanging the arse out round left handers
jmc330i
Really? What happened?Jhonno wrote:I did.. Fine with AKG's..jmc330i wrote:Ive had no problems with mine.feens wrote:As title ive read that the e28m5 engine mounts are a bit soft for the s50 conversion
James
'91 325i Sport
'91 325i Sport
billgatese30
Steering UJ interfere's with the exhaust manifold. This means that suddenly no more lock is available, and if timed wrongly can mean its difficult to wind the lock off as it can jam the UJ in place (happened to me on a hairpin with a pit wall on the inside as I exited and wanted to wind off the lock....not nicejmc330i wrote:Really? What happened?Jhonno wrote:I did.. Fine with AKG's..jmc330i wrote: Ive had no problems with mine.
AKG's sorted that out though
jmc330i
Hell
How much room you got between the UJ and manifold? I wouldnt of said mine is overly close, but then I dont know how much the engine will move. Ive had no problems with mine, but Ive not tracked it yet.
James
'91 325i Sport
'91 325i Sport
billgatese30
I can't remember, it was starting to rain and I couldn't see much when I was changing them as my hands obscured the view. I don't think there's loads. start blipping the throttle with the bonnet open and see how much it moves, now add the cornering forces trying to move a 100+kg block of iron around and I'd imagine it moves even further. Its nice and firm on the AKG's though.
Dezzy
- CR24v it's a lifestyle
I have just ordered a pair for the M50. Will be handy for the future. I am tight so am only using 1 though. Another E30 3.0lt 24v is using the other.
The way I see it 1 polly mount on the right and 1 635 mount on the left £9 from pelican parts and I should be golden.
- Homo Hair
I fitted one.. My steering was constantly locked up as they are actually lower than the M5 ones..
Dezzy
By how much mate? Can it be spaced? Enough threads?Jhonno wrote:I fitted one.. My steering was constantly locked up as they are actually lower than the M5 ones..
- Homo Hair
Erm, not sure, I should have measured, but I didn't have a lot of time so just pulled and swapped the other one!
There isn't a lot of spare thread..
Dezzy
That might screw up plans. Rubbish!
- Homo Hair
Don't be such a tight northerner..
Dezzy
Ha ha tight norther and brummie mate.
I have been thinking of ways to space it. Maybe make a nut for the thread like a M50/2 rockercover nut.
Drill the crossmember to suit. Big built in washer job job'd I reckon
Stop panicking you daft geordie, it will be fine
Dezzy
Ha ha thought you would like that matey. It's these M3 owners trying to sh1t up us tight daft northen monkeys.DanThe wrote:Stop panicking you daft geordie, it will be fine
furbster
I had exactly that problem yesterday at Oulton Park (first trackday since the swap) Took me a while to work out what the problem was!!)billgatese30 wrote:Steering UJ interfere's with the exhaust manifold. This means that suddenly no more lock is available, and if timed wrongly can mean its difficult to wind the lock off as it can jam the UJ in place (happened to me on a hairpin with a pit wall on the inside as I exited and wanted to wind off the lock....not nicejmc330i wrote:Really? What happened?Jhonno wrote: I did.. Fine with AKG's..)
Am I correct in thinking the ones you are talking about in the link are part no #MM5030 ?
You must have been the white E30 I was struggling to keep up with
billgatese30
Yep they look like the ones. $200 is what I paid back then too.
furbster
Brilliant!billgatese30 wrote:Yep they look like the ones. $200 is what I paid back then too.
And just changing the mounts totally cured the problem??
billgatese30
Yep, 100% cured
furbster
Thanks!!billgatese30 wrote:Yep, 100% cured
I shall order a set up!!
furbster
Hey Dan!DanThe wrote:You must have been the white E30 I was struggling to keep up with
That would have been me!!
First time on track with that setup and what a differnt animal!.... Love IT!!
Sorry I didn't come say hello, I spent so much time driving or fiddling I didn't get to speak to any other zoners!! Which one were you driving?
Thats generally what happens, day goes so quick
I was in the lazer blue chariot, JEF plate, I was pretty much sailing past most standard looking E30's even though im still shite in some corners but remember one being particularly difficult!
furbster
I did see you there, was behind you on the way home for a bit too when I was trying to avoid the traffic jam!!
I wish I'd made the time to come and find you now so that I could have taken a look under your bonnet!! See how the wiring loom really should look!
I'm back there on the 27th for a drift day with MSV. I don't suppose you're attending that one are you?
That traffic was a nightmare! My mate broke down half way through it, ended up taking us 3 hours to get to the motorway
We saw another 2 cars broken down and an accident involving 3 cars
All for the sake of a few cones and a set of traffic lights!
Wont be there for the diffin, will probably be next year before im out in it again
furbster
I thought I saw you on the Motorway but I stopped for two hours in the pub to have something to eat and wait for traffic to die down!!!!
No doubt I shall be at many track and drift days next year so will probably bump into you at some point.
I best not keep spamming the thread!
I shall report back on this thread after fitting the mounts.
If you stopped for 2 hours then you probably did
- Homo Hair
Yes!!furbster wrote:Brilliant!billgatese30 wrote:Yep they look like the ones. $200 is what I paid back then too.![]()
SCOTT325SE
is anyone running a manual rack with these engines/mounts?
