For the S50B30 or S50B32 conversion can you fit:
ANY E36 Steering Rack?
Also...
Which Steering Coupling/UJ connection will fit the E30 column and the E36 rack?
Will the E36 Track rod ends fit E30 Hubs?
Can I use E36 power steering pipes?
Can i use the E30 reservoir?
Can i use a 1998 M3 steering wheel on an E30 column?
Wheres best to locate the reservoir?
Steering problems with the s50 conversion
Yes
E30 will fit but may need to use a spacer... it really depends on your manifold. Look for Danthe's thread on the slim-line couplings.
He's doing a group buy for around 60 quid at the moment
Yes
Parts of them
Yes, all the resivoirs are the same, just depends where you mount them and the orientation of the pipe routing to them.
Afriad not.
where-ever you think it fits nicely really
Yes
Yes
Parts of them
Afriad not.
No problem.
Actually best getting a non M E36 rack as they have lock stops or progressive steering.... neither of which is considered an advantage and plus the fact that a rack off something like a sh!tty little 4 pot E36 will be cheaper and have less wear and tear on it all things being equal rather than the heavier cars.
E46 rack is alittle bit better though and E46 Sport rack the best of them all if you can get one handy and if you don't already have an E36 rack.
