MOT'd....
maynee007
Post Thu Sep 06, 2012 5:46 pm
Some more pictures...
maynee007
Post Fri Sep 07, 2012 3:37 am
i just photoshopped a picture of an m3 cab with evo lip to see what it'd look like wit new beemer white
not perfect but nearly...doesnt look too bad does it??? if it turns out anywhere near this ill be chuffed!
maynee007
Post Fri Sep 07, 2012 3:49 am
Apologies to all the true petrolheads outhere waiting for the engine conversion to start but unfortunately good things come to those who wait...i would appreciate any advice that you more experienced gents may have for me in regards the conversion and what i could pre-plan in to help me achieve a better result, whether it be performance related or cosmetic, i.e. engine bay/rocker cover layout etc.....not all at once though!!!
maynee007
Post Sun Sep 16, 2012 7:25 pm
main body painted including engine bay
will get more flicks up soon...
maynee007
Post Mon Sep 17, 2012 5:45 pm
Body and wings have been sprayed with 6 coats of paint, they've started with the flattening in the pics below and will buff it after. Front n back bumpers, skirts and evo lip getting sprayed tomorrow, still waiting on interior and horseshoe!!!
fattasss
Post Tue Sep 18, 2012 11:49 pm
Lookin great THAT:)
maynee007
Post Wed Sep 19, 2012 4:48 pm
cheers me fellow newbie...
maynee007
Post Wed Oct 10, 2012 6:59 pm
maynee007
Post Fri Oct 12, 2012 2:14 am
front end is built up, evo lip fitted....
modded e30/e36 m3 sill plates
still awaiting smoked indicator lenses...
tuonome
Post Fri Oct 12, 2012 10:32 pm
what a build great job, were the wings n quater panels expensive?
jmc330i
Post Sat Oct 13, 2012 12:04 am
penton08 wrote:
maynee007 wrote:Just getting the last few bits for the engine conversion and i'm a bit confused regards what brake servo/mater cylinder setup to go with....I didnt want to be chopping the firewall or moving stuff so apparently im left with clio servo, audi s2, 325ix & golf!!!! I wanna know which one has worked best for s50b32???
None of the above servos will fit without moving it over!! The clio servo is the best i have used by far, Moving it over is not a hard job :D
The Golf and Clio servo will fit in the standard location if you mod the plenum, but having been there and done that, I'd say moving the servo over is by far the best solution.
James
'91 325i Sport
'93 318i touring 16v
maynee007
Post Sat Oct 13, 2012 7:38 pm
i bought the quarters from the stealers at £380 each and apparently it was the last set available, the front wings were off a coupe which we then welded with the bottom ends off my 318 wings.
maynee007
Post Sat Oct 13, 2012 7:39 pm
i was told i need a brake bar from an e34 for the servo relocation???
jmc330i
Post Sat Oct 13, 2012 7:45 pm
Yup, that's correct. It's the bar that runs from the pedal assembly, across the bulkhead to the servo linkage. It's longer than the E30 rod.
James
'91 325i Sport
maynee007
Post Sat Oct 27, 2012 3:45 pm
can anyone confirm what gearshifters ill be able to use with this z3m 5spd box? can i use an e30 one?
maynee007
Post Sat Nov 17, 2012 4:35 am
After some delays, finally the bodys been buffed, still not polished...i'm quite chuffed with how the paints come up, looking forward to it being polished and seeing it in daylight!!! Can't wait to get the engine in, still need manifold, needto rob a bank...quick!!!lol
maynee007
Post Sat Nov 17, 2012 7:40 pm
Ramses
Post Sat Nov 17, 2012 8:21 pm
Am looking to Start this exact project on my e30 white convertible did you use genuine m3 kit or is it replica it looks very nice so far, which ever way can you direct my can you put me in the right direction to source a kit like yours ?
maynee007
Post Sun Nov 18, 2012 3:16 pm
i bought all genuine parts convertible specific, the following link is for a guy that does fibreglass kit for £499 and kit+fitted to a convertible he charges £1400, thats pretty reasonable if your happy with doing a fibreglass.
This ones fibreglass
check this guy out hes cheap, read his description
http://classifieds.pistonheads.com/clas ... its/240366
maynee007
Post Thu Nov 22, 2012 9:48 pm
decided to not get the body polished, thought id get the engine dropped in first then do the detailing one time at the end.
maynee007
Post Wed Dec 05, 2012 2:08 am
can anyone tell me how far over i need to move the servo (clio) for it to fit in/work with an e34 brake bar on the otherside of the bulkhead? Can't seem to find an e34 brake bar either and stealers don't have em! Any advice please.
maynee007
Post Wed Jan 16, 2013 6:18 pm
Took the trailing arms off yesterday, got one of the e36 arms on to check BBS RC wheel fitment. Needed a drum roll really, got told allsorts of stuff in regrads offset anyways heres some pictures.
maynee007
Post Sat Aug 24, 2013 11:50 pm
modded the 6th....
maynee007
Post Mon Nov 11, 2013 11:37 pm
lumps in....
Pud237
Post Tue Nov 12, 2013 9:22 pm
Is that an original S50 exhaust manifold you've modified?
E30 M52B28
maynee007
Post Tue Nov 12, 2013 11:02 pm
Yep!
Pud237
Post Wed Nov 13, 2013 7:43 pm
Looks a million times better than the modified M50/M52 manifold I've got on mine! Nice welding skills :)
E30 M52B28
maynee007
Post Fri Dec 06, 2013 10:56 pm
a few more pics...
Got the new nuts and bolts for the rear hubs etc.....get it rollin and onto the four poster ready for the exhaust. Still need to get the radiator top mounts...I can see the light at the end of this tunnel now.
Jamie8GTi
Post Sat Feb 08, 2014 11:03 am
this ones looking really nice!
maynee007
Post Sun Feb 09, 2014 9:28 pm
cheers....lets hope it runs nice!!!
maynee007
Post Sun Apr 06, 2014 6:17 pm
Finally......exhaust has been completed and car is running sweet. Full service undertaken including gear oil and diff oil. Clutch and brakes have been bled. Sounds awesome!!! will try and get some vids uploaded!
maynee007
Post Thu Aug 07, 2014 4:10 am
maynee007
Post Thu Aug 07, 2014 4:35 am
Near completion now, needs 225/40/17s on the rear as arches are rubbing. Engine is running as sweet as Uwe said it was and the drive is suprisingly comfortable. I'll be posting a video up soon.
daniboi328
Post Thu Aug 07, 2014 9:58 am
Epic build thread buddy
In the middle off the same conversion myself.
What airbox are you using ?
maynee007
Post Thu Aug 07, 2014 11:52 pm
the airbox was custom welded aluminium then plasti-sprayed....worked well, looks factory don't you think? :D
