M42 exhaust manifold VS M44 exhaust manifold
adiethirteen
Post Sat Dec 04, 2021 10:43 am
Thought i'd post up a visual difference for these two as I struggled to find a definitive side by side shot when searching and there are many dodgy eBay sellers trying to pass off e36 M44 manifolds as e30 318is/M42 manifolds.
This is an e30 M42 manifold - What you want - Also found on SOME early e36's that came fitted with an M42 engine
..and this is an e36 M44 manifold - What you don't want
Notice how the centre two exhaust runners on the M44 manifold sit a lot lower and merge a lot later than on the M42 manifold.
In situ these will interfere with the steering column linkage on your e30 and cause no end of fun.. And yes, while you can "make" this work with a love tap from Mr Hammer, it is far from ideal as you're restricting the flow of the exhaust gases and cocking up the harmonics. Which on this peppy little engines is the last thing you want to be doing, so always worth hunting out a proper M42 manifold.
Post Sat Dec 04, 2021 12:56 pm
I`ve made this a "sticky" as this is a very clear and precise example of what to look out for .
:clap: :clap: :clap: :clap:
