Hello everyone,
I am a new member and I am in dying need of all of your thoughts and opinions!
I own a 1987 318i, the engine is a m40b18, I have just rebuilt the top half of the engine due to a blown head gasket!
However now everything is back together the car will only crank and will not start! I have checked for spark and I have a nice one, i know there is no fuel entering the engine as I pulled out a spark plug after cranking and it was dry, so the problem I feel lies with the injectors? Is there a common fault here? I'm not sure what to do next!
( I DO have fuel pressure)
Thanks jack[/i]
M40b18 not starting!! Need help
On my 316i, the plug for all the injector fell out of the connector during driving. Have you checked that? Also check if the fuel in and out are connected correctly.
You made exactly the same post three days ago, which has been replied to with questions asked, but you still haven't posted a response. Please continue in that thread, and answer the questions asked if you want our help.
