M40 vacuum hose diagram
iainel
Post Fri Feb 21, 2014 11:31 am
Hi all
Does anyone have an M40 vacuum hose diagram I could use to replumb one please?
Reason I ask is since doing a headgasket on an M40 318i it idles ever so slightly lumpy. The only hose I can't find where it goes is what I believe is a fuel tank recirculation valve in the engine bay?
broadie
Post Tue Feb 25, 2014 8:02 pm
Have you looked on real ome for the drawings.
I use soapy water in a trigger spray to find small air vacuum leaks as it will tempary seal the leak.
Post Tue Feb 25, 2014 8:09 pm
iainel wrote: The only hose I can't find where it goes is what I believe is a fuel tank recirculation valve in the engine bay?
That's because you're in the UK and your car doesn't have all the emissions related rubbish.
You should, however, have a small rubber emerging from under the throttle body, with a plug in the end of it.
Only vacuum hose on an M40, apart from that one, is the one to the brake servo.
