EWS help
broadie
Post Sun Apr 07, 2013 11:54 am
Hi
Been offered an M42 engine to replace the M40. The M42 is from a 1995 E36 that had EWS it comes with loom and ECU. But no key or other EWS bits. Will this be a problem?
Thanks Broadie
eko
Old timer
Post Sun Apr 07, 2013 12:34 pm
Either get the ecu flashed to remove the ews or probably easier and cheaper to just get an e30 m42 loom and ecu to use on it.
broadie
Post Sun Apr 07, 2013 12:39 pm
Will an EWS delete chip have the same result?
eko
Old timer
Post Sun Apr 07, 2013 12:40 pm
Pm Danthe he can flash the ecu to remove it.
broadie
Post Sun Apr 07, 2013 1:59 pm
Cheers eko I'll see what Dan says.
