Hello,
I will rebuild my M40 318i engine, but I'm thinking of cranking up the power with increase the capacity of the engine.
any info about that? data?
I'm know someone has increase it to 2000cc, any data on how much HP gain? and does the compression become increase to?
what part needed? with part number?
does is it need to re set up ecu? injector? or I just replave the crankshaft, piston and conrod?
Thank you
Markus
any info to max cylinder volume on M40? what part I need?
