Engine trouble
Jymbow
Post Sat Sep 08, 2012 4:42 pm
Hi guys
I need some help and advice my e30 316i (89 plate) keeps cutting out when driving and the revs drop or when i dip the clutch, the impulse sensor lead has broken, when i ordered a replacement set of plug leads the plug on the new leads has a rectangular three pin plug attached but my old sensor appears to be part of the lead.
also my idle control valve is appears not to be working correctly after looking on the internet it says it should have an OHM reading of about 20 whereas mine was reading OHM 0.8, is this correct?
Does anyone know where i can get a set of leads that will fit and an idle control valve at a sensible price?
thank you in advance
James
