Anyone running bike carbs?
JdmFanBoy
Post Mon Jul 23, 2012 3:08 pm
Stumbled across this picture
Got me thinking if it would be worth doing?
My mate runs bike carbs on his F7R swapped Volvo and that thing goes like a little rocket.
What would be involved in fitting bike carbs to an Injection M40 or M42?
As far as I know you'd need:
Bike carbs (GSXR, R6, R1, Fireblade)
Some sort of custom inlet made up
modified throttle cable
low power fuel pump or a fuel pressure regulator
Drilled or larger jets
The part I think would be tricky is getting a spark to it?
Just something to think about I guess :D
staley_turbo
Post Mon Jul 23, 2012 3:09 pm
I did this on a 106, Very good cheap upgrade. Sparks already there, you leave that alone. Just remove the injection system and add the carbs.
JdmFanBoy
Post Mon Jul 23, 2012 5:01 pm
Oh ok I was under the impression you needed a distributor to retard the timing etc.. How much power did you gain and how much worse on fuel was it?
staley_turbo
Post Mon Jul 23, 2012 9:52 pm
You can, but you could also get a chip made, someone on here does them I'm sure he can make custom ones. Power gain was good for what it cost, the noise was the best part! Fuel was awful, but thats somthing you have to live with.
JdmFanBoy
Post Mon Jul 23, 2012 11:32 pm
I heard people were only loosing 5mpg when they were just cruising? Mines a daily so if the fuels that bad I may have to reconsider :( Was really hoping to do this aswell :evil:
staley_turbo
Post Tue Jul 24, 2012 7:22 am
The noise is worth every penny!
JdmFanBoy
Post Tue Jul 24, 2012 3:53 pm
I'm sure it sounds great but I'm not made of money :P
