I'm nearly ready to put the engine in my track car, but I need to sort out the fuel pump. The car is a 316 (carb). I've installed the 318is fuel pump and added a return fuel line.
What do I need to do to get the pump running? Is there any redundant wiring in the 316 I can use? Or should I just take a new switched live from the fusebox to the fuel pump?
Conversion fuel pump wiring
chips
- Was Pzero
