if i drop a 318is engine in my 316i?
cheers
what do i need to think about..
Touring Whore
I'm planning this one, and off the top of my head, the things to bear in mind are...
Coil pack mounting - either weld a plate to the inner wing or do the COP conversion.
Gearbox - if using the gearbox from the is the prop will need changing too.
ECU
Engine mounts - M42 or I think there are some M50 mounts that fit.
http://www.e30zone.net/modules.php?name ... c&t=158966 is the thread I started, there's a couple of good links to threads in there. I'll try to do a difinitive list when I do my swap, so it's there for future reference, but there's a lot about it on the forum already
ECU
kingludba
Im planning this conversion on my 93 e30 316i touring, do I need to change gear box or can the m42 bolt staright onto mine??
zimmerkid
m42 bolts straight up mate
