M42 bosch motronic 88 pin diagram
NoTurbo
Tue Nov 01, 2016 8:02 pm
Hi guys
Does anyone have a verified and accurate diagram of the motronic pin outs in an m42 175 ecu?
Wed Nov 02, 2016 12:11 am
NoTurbo
Wed Nov 02, 2016 9:41 am
Thanks Brian you are appreciated
NoTurbo
Thu Nov 03, 2016 11:48 am
It is unclear from your provided wiring diagram if the Coil pack, spark trigger wires are connected to each other.
I think its the middle one in the coil connector.
Do you know if these are connected anywhere in the loom?
Thu Nov 03, 2016 1:18 pm
Don't understand your question. Coil triggers are quite clearly separately connected to ECU pins 24, 25, 51 and 52.
NoTurbo
Thu Nov 03, 2016 1:33 pm
yes, but are they connected together after the ECU at any point in the loom?
I am wondering if they fire independently or is the sequential firing the result of a combined signal?
If I were to connect a multimeter across any two the trigger wires at the coil plug end would I be able to measure continuity between coil plugs?
Thu Nov 03, 2016 1:46 pm
Can all be fired independently.
With the ECU and coil packs unplugged, there should be no continuity between any of the trigger wires.
NoTurbo
Sat Nov 05, 2016 2:29 pm
Thanks for the help, i have continuity across pins 2 and 3 but not pin 1.
Does that mean that pin 1 is the trigger?
NoTurbo
Sun Nov 20, 2016 8:55 pm
Bump
Sun Nov 20, 2016 9:10 pm
?? Wiring diagram clearly shows that pin 1 of the coils is the trigger. 2 is earth for the secondary, and 3 is 12 volts+ for the primary.
NoTurbo
Fri May 05, 2017 3:50 pm
Thanks Brian, sorry for the confusion on this one.
