piper re-ground cams
Tonyy93
Sun Aug 28, 2011 11:01 am
are they going to be worth getting done :/ it costs about 140ish but will there be any gains and will i have to put my timing back to normal because atm iv got it advanced ? any help welcome :D
cheers tony :)
rix313
Sun Sep 11, 2011 11:33 am
Where did you get that price from? Any specs?
I've had a look at the Piper website
(http://www.pipercams.co.uk/pipercams/ww ... BMWISBP270)
Power band: 1500-6000
Duration Inl & Exh: 264deg
Valve lift Inl & Exh: 10.16mm
Full lift: 110deg
Timing: 22/62 Inlet 62/22 Exhuast
And also Kent cams
(http://www.kentcams.com/product-details ... Injection/)
Power Band: 2000-6500
Duration: 256 Deg Inlet/Exhaust
Valve Lift(mm) 10.36mm Inlet/Exhaust
Full lift: 110deg
Timing: 18/58 Inlet 58/18 Exhaust
Not sure how much the Kent cams are though.
Tonyy93
Sun Sep 11, 2011 12:10 pm
the price i got was to have my cams re ground would that be the same and its a trade price i called them the other day, i havnt spoke to kent cams il try give them a call tomorrow il let you no what prices they come back with :)
cheers :)
rix313
Sun Sep 11, 2011 7:51 pm
Sounds good :thumb:
