Rocker cover gasket
Tedswagon
Post Fri Apr 14, 2017 8:59 pm
Hi all,
Engine - M52 2.8 - donor car reg S161 EWH
I want to replace the hardened gasket as above. I bought a cheap aftermarket one of someone on here and found the semi circle bits to fill the cut out for the cams had tabs on it where it should have had insets (see photos). Because I got it for cheapness I thought - must have the wrong one - I'd just cut the tabs off and see if I can make it fit . . that didn't work!!
Original one showing the slot
inside side of the rocker cover.
Showing the two - the new one has tabs and bits sticking out where it should have slots
So I bought an OEM one from the stealers on here and when it arrived its the same as the one I butchered earlier!! Am I missing something? Is there a mod required for the gasket??
