M52b25 and m52b28 differences
Gavt
Post Sun Nov 27, 2016 10:42 pm
Im asking as i can get a cheap m52b25 and im told its just the crank thats different. So my question is if im building a m52b30 stroker can i start with with the 323 engine and change the crank and cams ect or should i start with a 2.8
Motorhole
Post Tue Nov 29, 2016 8:24 am
Gavt wrote:Im asking as i can get a cheap m52b25 and im told its just the crank thats different. So my question is if im building a m52b30 stroker can i start with with the 323 engine and change the crank and cams ect or should i start with a 2.8
You can - injectors, crank, rods and pistons are different between the M52B28 and M52B23. Everything else is the same iirc :D
