ECU shenanigans
Ive just bought myself an M50b25, however it never came with an ecu =( Im looking into getting the correct ecu for it, i know that this engine had ews so am I right in thinking I need a silver tag 413? Obviously with ews delete? any help would be much appreciated <3
- Brianmoooore
You need a purple label 413 (= silver label 413 without EWS.) Totally interchangeable.
- Brianmoooore
red = purple. Actual colour is more maroon.
HairyScreech
The only difference between the red and the silver is what has been written onto the chip, silvers are non-ews after fitting an aftermarket chip.
Programming the ews in the chip is a ball ache so 99% of aftermarket chips use the red label program.
tbh i even struggled finding ecu's with the ews!! plenty of red labels about so I should be all good. Ill be after a remap and raised limiter anyways. Just wish I actually got an ecu with the engine =(
Getting the loom all ripped off this week and hopefully sent away to DanThe so he can work his magic =P
