Has anyone used one of these?
http://www.akgmotorsport.com/catalog/ca ... M50%20Swap
AKG Wiring Loom Adaptor
ross_jsy
I'll take a wiring loom off Dan for similar money (perhaps less, can't remember what I paid) that looks OEM and doesn't have an extra connector in there any day
A very expensive and inelegant solution to a simple problem, and does nothing to address the fact that various bits connected to the loom, that are not actually on the engine, are mounted in slightly different places in an E30 engine bay. I think I'm right in saying that Dan's looms are 'adjusted' for a better fit.
If you just want to fit the E36 loom as it is, then an E30 C101 plug, complete with 300mm of wire, some heat shrink sleeving, a soldering iron, and a spare hour are all you need.
By the time you put shipping and taxes into it that adaptor is indeed more than my loom that fits the engine bay perfectly, but more importantly is made to work with your car
LondonTom
Thanks guys.
The main reason I asked is I can get it without shipping and taxes.
jmc330i
It's still nearly £150 for something you could DIY easily enough as Brian says (and be better than that adaptor).
I usually DIY it, but my money would be going to Dan for one of his looms if I did another conversion.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
ferndaleluke
How much are your conversion plugs Dan? ?
johnmaccow
Just done mine 2 weeks ago, never soldered before, gas soldering iron £20 ,solder £3 and two quid for heat shrink.
Used the guide on here and done in an hour.
Wish I had sent it to Dan to do so would be neater but wanted to try soldering and was off work.
Motorhole
Dan's looms make the whole thing look like a factory installation - loom cover across the bulkhead and all. Well worth the money.
