Intake elbow
mcjjordan
Post Tue Oct 27, 2015 11:31 pm
So where can i get a nice silicone intake elbow
One end needs to be 80mm the other 75mm
And i have no take offs so just a straight throught 90 degree pipe
Cant seem to find one that has the different size ends
Or have i got some wierd size afm or throttle body???
Www.jvsautoelectrical.co.uk
Alarms,immobilisers,trackers,locking,windows,rewires,fire damaged,mobile service in hampshire.
Post Wed Oct 28, 2015 8:42 am
Ideally you will have the correct throttle/MAF for your engine/management,
Samco is probably the best available, I have them on my cars but bought from the US
https://www.merlinmotorsport.co.uk/p/sa ... Alry8P8HAQ
HairyScreech
Post Wed Oct 28, 2015 10:52 am
Viper performance do a massive range and I have found their stuff to be pretty good without the price of the samco stuff.
https://www.viperperformance.co.uk/subcats.php?xctId=36
I have one of their big 90 deg reducers and the taper on it is quite nice and smooth.
80 - 75 is a tricky size though.
You will fine it is all 80-60 or 83/89-75.
For an 80-75 I would be tempted to stick 2.5mm rubber around the diameter of the 75mm part and use a non reducer hose.
What engine do you have? I can confirm the size of the 328 M52 and 325 M50 MAF is the same, will check what that is later tonight.
mcjjordan
Post Wed Oct 28, 2015 6:00 pm
Its m52 2.8 but it has the m50 manifold but its a special doctored one apparently by alpina527
It may have a big bore throttle body but ive nothing to compare it to
HairyScreech
Post Wed Oct 28, 2015 7:00 pm
Take a measure of the outside of the throttle, the bmw based big bore throttles are made using the stock outer housing.
mcjjordan
Post Wed Oct 28, 2015 9:27 pm
I did think it was 75mm
But when i measured afm was 80mm
Maybe someone could measure theirs and comfirm
HairyScreech
Post Wed Oct 28, 2015 9:34 pm
You got a stock AFM?
If so the AFM I have here is 80mm
mcjjordan
Post Sun Nov 01, 2015 8:27 pm
80mm afm and 75mm throttlebody
