Removing A/C pulley
redcar
Post Thu Aug 27, 2015 3:05 pm
Hello,
So I've removed the A/C pump, associated brackets and also the pulley.
After removing the pulley and tightening up the 6 bolts back on the main crank pulley, the engine doesn't turn by hand (engine is out of car)
Am I missing something here? I have another m52 engine here which had no A/C pulley from factory and that has the same 6 bolts on the crank pulley and I can turn that engine over by hand.
Thanks in advance.
jmc330i
Post Thu Aug 27, 2015 3:19 pm
The pulley bolts are specific for aircon or non-aircon - M8x12 for non-aircon and M8x18 for aircon I believe.
If you've removed the aircon pulley your bolts will be too long and touching the engine and jamming it up.
Either get the shorter bolts or refit the aircon pulley.
James
'91 325i Sport
'93 318i touring 16v
redcar
Post Thu Aug 27, 2015 3:32 pm
Thank you for the quick reply and help.
