Head surface finish once skimmed ?
hotross
Post Sat May 09, 2015 9:33 pm
Hi all..
Hope you can give me a answer on this one.
Picked up my head from the machine shop today and i can see marks left by the machine on it. I thought they are meant to be like mirrors once done and it's a little ruff on the surface too ?
First time i have had a head skimmed so not to sure :?
Post Sat May 09, 2015 10:21 pm
The finish shouldn't be mirror. The gasket needs a keyed finish.
hotross
Post Sat May 09, 2015 10:40 pm
Cool thanks :D
I've been watching youtube too much lol
Keiron
**BANNED**
Post Wed Jul 29, 2015 9:31 am
B7 wrote:The finish shouldn't be mirror. The gasket needs a keyed finish.
The finish should me like a mirror if your using an MLS gasket !
Even if your not the finish should look like a record with oil colours if you get my grasp ?
Some machine shops are still using grinding stones for cast iron heads on alloy heads this is not right they should be done with a fly cutter you should really check first hope this helps
