M52B52 Tachometer
Jens24el
Post Tue Mar 24, 2015 5:49 pm
I am doing a M25B25 swap from a 97' E39 523i to my 84' 323i, the last thing i need to do is the tachometer.
I can't the tachometer signal wire from the engine plug. The E30wiki says it should be a black wire, but that is on a E36 engine plug, and i cant find a good diagram for E39 engine plugs.
Is there anyone who has done this conversion who could help with the last bit of wiring???
Post Tue Mar 24, 2015 7:06 pm
RPM signal comes out of the ECU plug at Pin 36, Black wire, trace it through the loom is the best bet
