Clio Brake servo
mopsdrops
Post Sun Feb 01, 2015 11:08 am
Hello, I've fitted a Clio brake servo on my e30. I also used a 20mm bullet to fit in the master cilinder. But now everything is mounted; my brake pedal is still way more down the floor then it supposed to be. Is there something wrong or I forgot? Do I need to di something with the adjustment rod of the servo?
nickso
Post Sun Feb 01, 2015 12:13 pm
Are you sure the bullet is long enough? 20mm is the "average" but some have had to make theirs longer/shorter. Mine was around 25mm I think but I'm using an M3 cylinder. I had to fiddle about with the linkage to get it just right.
Just mess about with it till you get a better feel.
'88 e30 328i M52 track bint.
mopsdrops
Post Sun Feb 01, 2015 12:55 pm
Okay, thanks, but the adjusment rod needs to be all the way out? how can I get this rod stick out furthermore?
mopsdrops
Post Tue Feb 03, 2015 6:52 pm
Anyone?
mopsdrops
Post Wed Feb 04, 2015 5:06 pm
And how can I adjust this brake pull rod ??
Thankyou
mopsdrops
Post Fri Feb 06, 2015 4:56 pm
Anyone? thankyou
Post Fri Feb 06, 2015 8:08 pm
Take off the under dash panel on the driver's side, and open the glovebox on the passenger side, and you will be able to see both ends of it. It has a normal thread on one end, and a reverse thread on the other, so loosening the locknuts and turning it will change its length.
There are a couple of flats on the rod near to where it passes the clutch pedal which fit a 7mm (?) spanner to enable you to turn it.
