propshaft on m50 conversion with m3 6 speed g/b
hass
Post Mon Dec 08, 2014 6:11 pm
Hi
after having no luck selling me sport
im gonna go with the m50 2.5 conversion.
my question is im getting the m50 with the 6 speed m3 gearbox
what do i do with the props.
can i use a e36 prop or does it have to be custom made for the m3 box.
will it still be cool to use my standard lsd or do i need to cahnge that too.
many thanks Hass
jimbom30cab
Tech 1 freak
Post Mon Dec 08, 2014 6:28 pm
It should be custom, basically you need an e30 m3 prop or e36 328i manual prop which needs to be shortened by 7cm
If you send if off then they will balance it also
There is a thread in the m50 section
Costs about £100
Both these props have the larger guibo which you need to fit the GB output flange.
hass
Post Mon Dec 08, 2014 6:38 pm
Hi Jimbom
thanks for the reply
so ill need a 328i manual prop or e30 m3 prop with my original rear prop and still get it shortened?
or is it a straight fit?
age
Formerly twist316
Post Sun Dec 21, 2014 7:28 am
rumour has it an e36 m3 auto prop is a direct fit
M40 rightness if you can get to 6000rpm noone can hear your tappets
jimbom30cab
Tech 1 freak
Post Sun Dec 21, 2014 9:09 am
Sadly not. There is a thread about this in the m52 section I think
The nearest fit is an m40 auto prop from e30
