Hi guys,
I have just put an M50 into my e30 and am nearing completion.
A little bird tells me that there is someone on here who sells a custom rack to pump power steering pipe?
If so, could someone point me in the correct direction. I have had a search but cant find anything.
power steering pipes after an m50 and e36 rack swap
russ325i
I'm pretty sure that the man you're looking for is DanThe.
I live in the Channel Islands so took mine to a local hydraulics fabricator who turned it around in a couple of hours replacing the flexible hose of the line running around the rear of the crossmember with brand new digger hose to delete the solid bit that goes back onto the fitting before the pump which was ideal (mine was a little short on that end, the other line was absolutely fine with an M52 and Z3 rack). He kept the restrictor in the same place too and all for £50. Job done!
ChopperE30
cheers,
i have given dan a message
