Any body done them before on the ally block ?
my mates head has gone and like to know whats the best serts and kit for it
Time serts
scoobydo
yes they are the bees knees. Just make sure you get the correct inserts taper or normal. Even used them without taking off the head. You can also get ally inserts so the material matches the head for the correct heat transfer but stuggle to get them inserts in the uk as they are more for the drag racing high hp guys in the states.
rich318i
What time sert kit did you use or have?scoobydo wrote:yes they are the bees knees. Just make sure you get the correct inserts taper or normal. Even used them without taking off the head. You can also get ally inserts so the material matches the head for the correct heat transfer but stuggle to get them inserts in the uk as they are more for the drag racing high hp guys in the states.
scoobydo
I have the TIME-SERT M14 X 1.25 Spark Plug Repair Kit 4412
