Oil pump upgrade
ross_jsy
Tue Aug 12, 2014 6:13 am
While the engine is out and getting rebuilt, I'm wondering if it is worth either installing a new oil pump or if there is anything considered a worthwhile upgrade?
I'll be welding the nut on.
Ross
ajay
Tue Aug 12, 2014 8:14 am
Not heard of many M52 swappers doing much with their oil pump, VAC motorsport do an upratted exchange pump rebuilt with higher output and stronger pump shaft, with a split pin nut guranteed not to fail, ( they recon shafts can fail even if the nut stays in place).
Not cheap, but how necesarry it is who knows!
ross_jsy
Wed Aug 13, 2014 1:51 pm
Cheers I'll have a look but I always find VAC stuff quite overpriced. Was hoping there might be an OEM solution
Kos
Wed Aug 13, 2014 4:33 pm
New OEM I'd say is your best bet
www.pukardesigns.com
IG Pukar.Designs
HairyScreech
Wed Aug 13, 2014 5:49 pm
Not really heard of the flow from the pump ever being an issue, these are tough gear pumps not vane pumps.
I don't know of anyone in the uk offering the uprated pump shafts.
