m50 tightening specs
ross_jsy
Has anyone got a list of the torque specs for m50's?
Ross
Ross
rich318i
head or bottom end?
ross_jsy
Everything. Tolerances for crank would be useful as well
rich318i
you running M10's on the head bolts?
Thats 30Nm then 90 + 90 angle for the head
crank is 20Nm angle 50
Cams are 15NM
Cams are 15NM
ross_jsy
No I'll be going for LRP's so don't need to worry about head bolts, 85ft pounds seems recommended
Cheers, found this as well, bit confusing to read but all the info is there
http://www.bmw-m.net/TechData/torq/bmw_torq.pdf
rich318i
yeah thats the baby!!! Most of setting are used across the board you will find, apart for the M's regarding head and bottom ends
rich318i
you worked it out yet ?
ross_jsy
Yeah it's pretty simple once you get into it.
Been trying to get the crank bolt off. Had to buy a new 3 foot breaker today as my old one has gone MIA and I thought I was going to snap this one it was bending so far. Stuck a 6 foot bit of scaffolding on it and still no joy.
A mate is bringing round an electric impact gun tomorrow, hoping with some heat it will shift
rich318i
think they are reverse threaded righty = loss
ross_jsy
Thought that but google says it is normal thread
rich318i
bang the bar with a club hammer to shock it and not just pull on it does works and i do mean hit the bar and not tickle it
ross_jsy
Bar would just bend, it's a cheap Sealy. Heat and manning TFU will get it going tomorrow
rich318i
the bar is needed but if you bang it at the top with a club hammer and not pull it should come free
rich318i
they are 410 nm 300 lbs
craigieeb
I have in my possession a pdf of the E36 haynes if thats any help...
M50 Turbo!!!
I shall say no more
