Chip for OBD1 M52 2.8 with M50 inlet and BBTB
Avus525
Fri Jun 27, 2014 9:49 pm
Hiya chaps...
Does anyone on here do a chip "mapped" for an OBD1 converted M52 2.8 with an M50 inlet manifold and BBTB? engine also has charcoal cannister delete if that makes any difference to the map :)
ECU will be the infamous 413 red label from an M50 E34
TIA
jimbom30cab
Tech 1 freak
Fri Jun 27, 2014 10:54 pm
drop a PM to "Danthe"
neilp2810
Sat Jun 28, 2014 8:51 am
i have an m52 2.8 ecu already chipped for m50 inlet pm me!
Avus525
Sat Jun 28, 2014 2:55 pm
Thanks, after discussing via PM it turns out it's the wrong ECU type... Although I did point out which ECU I'm using and that it's for an OBD1 set up ;-)
I have sent a PM to "Danthe" - Thanks Jimbom30cab :D
