Fitted the Condor Speed Shop engine & gearbox mounts yesterday. Obviously jacked the engine up 2 inches or so to remove old mounts and put new ones in. Since I”˜ve put everything back together, the car”˜s been running like a sack of shite.
Sounds okay at idle, but sounds strained when revved. No power, flat as a fart at any rpm. Sounds awful from inside the car.
Noticed when I came back from my test drive that the engine control module relay had been popped out the loom where the fuel rail cover had put some pressure on the loom against the bulkhead. Popped this back in, no difference - must”˜ve still been a connection though because from what I gather from wiring diagram, engine shouldn”˜t run at all with this removed? Been over the car today, checked everything - vacuum leaks, connections, fuses, relays, engine earths - all looks good so I”˜m at a loss for what I”˜ve done. Any help or suggestions regarding where to look would be great!
Edit: forgot to say, engine”˜s a 1996 M52B28
