m50 VS m52 ENGINE LOOM
Quaser
Post Tue Apr 08, 2014 7:59 pm
Hi
Is there any difference between an m50 and m52 loom?
I have 2 e36's - a 325i and 328i - would it be possible to swap the engines around (m50 in the 328i to turbo as it has a better shell and traction control - and then m52 on the m50 loom to sell on)
Q
Post Tue Apr 08, 2014 8:00 pm
Yes lots different, although you can run an M50 with an M52 loom/sensors/ECU
Quaser
Post Tue Apr 08, 2014 8:24 pm
can I do vice versa? what would I need to swap over?
Post Tue Apr 08, 2014 8:48 pm
Quaser wrote:can I do vice versa? what would I need to swap over?
Yes but it would be a downgrade, same as listed above
Quaser
Post Tue Apr 08, 2014 9:05 pm
ok - which sensors exactly - cam and crank only or others too? im going to be going vems so not sure on what I need to change. unless the traction control wiring is separate - do you know if it is?
