any one no wear i can get the 5500rpm rev limit removed in kent?
cheers
rev limit removal
ross_jsy
There isn't a 5500rpm rev limit. Believe that's a problem with the speed sensor but someone who knows more will tell you.
rich318i
did you sort it?Sx279 wrote:any one no wear i can get the 5500rpm rev limit removed in kent?
cheers
Sx279
all done i used a company called 'end tuning' in birmingham.
£40 inc return p&p moved rev limit to 7k, ews fucked off as well..
3 day turn around highly recommended.
Sx279
rich318i
sweet but it was a easy fix any way i still like the EUC to know the speed signal for the remapping if you ever go that far
