E30 M52 Clutch high biting point
tbone455ci
Post Fri Jan 10, 2014 12:48 am
Hi
I done the m52 conversion over 6 months ago using the standard e30 325i gearbox, with lightened M20 flywheel & Sachs clutch kit with new master & slave cylinders.
The clutch biting point was very near the top but now it is pretty much at the top?
I have seen websites that recommend using e21 release bearing, would this lower the biting point?
Im going to adjust the eccentric bolt on the end of the clutch master the weekend but I believe this will only adjust the height of the pedal & not the biting point.
Has anyone else had this problem or a solution?
Post Fri Jan 10, 2014 7:48 am
If your using the M20 box, fly and clutch then you are steup as BMW would have intended so shouldnt be having any problems. It probably just needs bleeding a bit more thoroughly
tbone455ci
Post Sat Jan 11, 2014 11:35 pm
Cheers mate, will let you know when I blows it up....
tbone455ci
Post Fri Jan 17, 2014 9:00 pm
sorry I meant bleed it up, going to do it tomorrow....
