m50 that goes tic tic tic
JF008
Thu Jan 09, 2014 12:01 am
Hi, my non vanos m50b25 goes tic tic tic, the sound is in tune with the revs and seem to come from the driver side. Its sadly reminds me of my previous m40 engine's tappets! I searched the web and found that it could be the valves or the chain tensioner? oil level is good.
Any advice would be much appreciated!
JF
AndyZippy
Thu Jan 09, 2014 8:09 am
Sounds like it could maybe also be exhaust manifold (likely gasket, or a loose nut/stud)?
Motorhole
Thu Jan 09, 2014 9:18 am
Could be batch firing injectors due to failed cam sensor too.
True using a long screwdriver as a stethoscope to source the noise before spending any cash!
Thu Jan 09, 2014 9:26 am
As said could be an exhaust leak on the manifold, near the head.
Could also be a loose sparkplug depending on how many limp wristed mechanics have been working on the engine :)
JF008
Thu Jan 09, 2014 11:45 am
Would a failed cam sensor show on the diagnostic machine? could it explain why I have fluctuating revs on cold start ?
JF008
Thu Jan 09, 2014 11:46 am
Thanks for the replies too!
JF008
Sat Jan 11, 2014 9:36 am
The cold start issue disappear when unplugging the MAF. The car was remapped few days ago hoping it will solve the cold start fluctuating rev problem, it gained in power but made the problem somewhat worse. I hope all those issues are linked and will be resolved all at once. The car is at the garage for investigation although any input always welcome : )
JF008
Tue Jan 14, 2014 7:27 pm
New cam sensor, same problem... I've just bought a new/used AFM (to solve the cold start issue) I hope that is it!!!!
AndyZippy
Tue Jan 14, 2014 7:42 pm
Have you checked your 'zaust manifold??
JF008
Tue Jan 14, 2014 9:31 pm
Yeah its all nice and tight unfortunately!
Tue Jan 14, 2014 9:48 pm
What exhaust manifold is it? Any pics?
JF008
Tue Jan 14, 2014 10:23 pm
Its a fritz bits one
Tue Jan 14, 2014 10:49 pm
Proper job then. Id be surprised if it was a manifold leak but it has been known for craftsmen to leave a slight gap in welds :)
Are the plugs tight?
JF008
Sat Jan 18, 2014 4:08 pm
I checked the plugs, all good there. Also installed the right Bosch AFM and it cured the cold start issue :)
Now I have to investigate the ticking further as in this thread: http://www.e30zone.net/modules.php?name ... c&t=242399
It definitely comes from the top of the engine.
jellybellydrft
Fri Jan 31, 2014 11:33 am
sticky lifters?
