Fuel Pump Help!
Davidchurch
Sun Dec 08, 2013 5:34 pm
Right....
I was about to start the car for the first time. So i switched the ignition on and the fuel pump didn't fire up....
But as soon as I put a live feed to the pump I could hear it fire up.
Turned the key and boom! fired straight up!
I can put a live feed to both 13 pins and fire up.
Where do I check next? Thanks
rich318i
Sun Dec 08, 2013 6:52 pm
did you do the loom urself?
Davidchurch
Sun Dec 08, 2013 7:00 pm
The loom was already connected to the engine all i had to do was follow the instructions for which wire went where.
Connorquinn93
Sat Dec 14, 2013 12:27 pm
Check you got power going to the plug I had a fault on mine where the plug was a bit loose I bent the male terminals very slightly on the pump end to make more contact with the plug and its fine!
Sat Dec 14, 2013 1:53 pm
Needed to both pins? Check that the DME and fuel pump or lambda relays haven't been swapped around. Socket for the DME is the only one that has a wire to the centre pin.
TheMeathead
Mon Aug 04, 2014 9:08 pm
I'm having a similar problem atm, If I turn the key to position 2 the fuel pump doesn't fire. I've put a wire across pin 30 and 87 where the relay plug is and it fires up. I've checked the ecu, fitted a new crank sensor and swapped the plugs around but still nothing :(
I'm lost as to what it might be.....
Mon Aug 04, 2014 9:22 pm
TheMeathead wrote:I'm having a similar problem atm, If I turn the key to position 2 the fuel pump doesn't fire. I've put a wire across pin 30 and 87 where the relay plug is and it fires up. I've checked the ecu, fitted a new crank sensor and swapped the plugs around but still nothing :(
Fuel pump isn't supposed to fire up with the ignition switched on. It only runs in response to a signal from the crank position sensor.
Does the engine fire up and run when you have the fuel pump relay bridged?
TheMeathead
Wed Aug 06, 2014 9:19 am
Ah I see, now I feel like a tw*t :o: ive got it pluged it the right part now and it all works. Cheers
