Can someone tell me the thickness of the flywheel spacer ring that goes under the m20 flywheel bolts when installing an m20 flywheel to an m52?
M20 flywheel spacer thickness
2.5mm IIRC
The washer from an auto 24v is usually 5mm
Andeep
Ah, I have an auto one. That would explain why the thread engagement on the flywheel bolts was so short. Do you have a spare one by any chance?
