m52 keeps cutting out
Quaser
Post Mon Sep 23, 2013 9:40 am
Hiya
The car doesn't idle properly, and keeps cutting out. I took off the maf sensor and it idles better, but will cut out when I approach junctions.
I have tried 2 different mafs and still get the same issue.
Any ideas?
Q
nickso
Post Mon Sep 23, 2013 12:38 pm
Idle control valve round the wrong way or not working? That's what mine did when it was back to front.
'88 e30 328i M52 track bint.
Quaser
Post Mon Sep 23, 2013 12:45 pm
Car has been running fine until now - I must say that sometimes the exhaust pops on the overrun if that makes a difference
Post Mon Sep 23, 2013 1:02 pm
pm sent for loom info
Quaser
Post Mon Sep 23, 2013 1:27 pm
replied
Nas80
Post Mon Sep 23, 2013 1:57 pm
I had this - turned out the idle control valve where it takes the feed from the inlet elbow had come off and was letting unmetered air in.
Id advise you to check it again.
nickso
Post Mon Sep 23, 2013 5:56 pm
Quaser wrote:Car has been running fine until now - I must say that sometimes the exhaust pops on the overrun if that makes a difference
Mine does that a lot still. Never found out why.....sounds cool though. :)
Quaser
Post Tue Sep 24, 2013 11:27 am
checked all the vacuum hoses and afm / icv - its all connected fine
any other ideas?
nickso
Post Wed Sep 25, 2013 11:18 am
Is the ICV working though?
GB69
Post Wed Sep 25, 2013 11:27 am
idle control valve, or hoses going to it. My hose had a slight split and did the same thing.
Quaser
Post Wed Sep 25, 2013 7:50 pm
Ok nickso - you were right - thanks to everyone who advised the same thing (which is everyone lol)
While we are at it - how can I get the check engine oil light to go out once the engine is started like before
SteSE
Heading for the Naughty Room
Post Thu Mar 06, 2014 11:31 am
Quaser wrote: While we are at it - how can I get the check engine oil light to go out once the engine is started like before
Did you ever sort this. Mine does the same thing and also the coolant light.
How do you get the M52 low level oil / coolant sensors to talk to the check control?
87.5 Impact FM
PS3: gary_bunter
1986 325i resto - M52'd
C plates are fastest
Quaser
Post Thu Mar 06, 2014 11:40 am
i never did get the oil level sorted - and for the coolant light, i just stuck a wire in plug
SteSE
Post Thu Mar 06, 2014 11:49 am
Ok, thanks for quick reply.
There must be away to do this..?
87.5 Impact FM
PS3: gary_bunter
Post Thu Mar 06, 2014 12:14 pm
Ste the coolant level wiring is part of the body loom, will just need extending to the E36 level sensor which is located in the bottom of the expansion tank (if you have one)
The oil level wiring is part of the engine loom, I usually add this to the looms on request, dont ask me about yours though it was a while ago...
Easy to tell as there will be a loose 3 pin plug floating about by the LH side of the sump/PAS pump
This will also only work properly if your sump has a level sensor fitted
SteSE
Post Thu Mar 06, 2014 12:19 pm
sexual - cheers matey will get checking this weekend and report back!
87.5 Impact FM
PS3: gary_bunter
Post Thu Mar 06, 2014 1:45 pm
Note that the coolant level sensors for E30's and E36's are different, although (almost) identical in appearance. Use the wrong one, and the light will come on when the level is fine, but stay off when it's low.
