E34 Sump fitting onto M52
Andeep
Post Mon Aug 26, 2013 9:42 pm
Been searching for a while and can't find anything.
What needs to be done to fit an E34 M50 sump to an M52B28?
What windage tray needs to be used? What needs to be ground or cut off?
Post Mon Aug 26, 2013 9:56 pm
Leave the E36 baffle plate on the engine, just cut the oil pickup bracket off it. If the sump has an alloy plate in it will need cutting out
