engine flush M52
rich318i
Worth doing or leave it be?
Jamie8GTi
everything i have ever heard about flushing has always been a big no, if the engine is out it pays to clean the crap from the sump and pick up pipe but aslong as the engines been looked after and serviced at correct intervals it shouldn't be to bad.
Ive heard a pint of petrol in the oil works wonders
rich318i
fairy liquid more likeDanThe wrote:Ive heard a pint of petrol in the oil works wonders
Dont be ridiculousrich318i wrote:fairy liquid more likeDanThe wrote:Ive heard a pint of petrol in the oil works wonders
Jamie8GTi
The petrol will dilute the oil and essentially strip down some of the sludgy build up, personally i could see it working although when I asked about it concerning another car. I was warned running the engine like this even for a few minutes (which was suggested to me) could potentially cause damage. All in all, unless there is a terrible sludge build up I wouldnt advise touching it especially if you're going to use fairy liquid
rich318i
was told use Diesel but not going to do any of it just leaving it be. Not broken so no point in fixing it.
Just wanted to see if others have done it
ross_jsy
You don't use diesel, you use diesel oil as its got a lot more detergents in it that normal oil.
I have done an oil and filter with diesel oil, dropped the oil and filter after 500 miles and filled with normal oil. Pulls some shit out that's for sure.
rich318i
but how did it sound after?ross_jsy wrote:You don't use diesel, you use diesel oil as its got a lot more detergents in it that normal oil.
leeparkes
I flushed a Rover engine years ago, smoked like a bastid after.
pianist
should never flush your engine unless you want some trouble in the future like: leaks, premature wear, f***ed oil pump etc.
Want a clean engine then take it appart and put it back together after you cleaned all bits in diesel and soked in oil replacing all seals with new ones on the way
